Windows 10/11 Download
Since I have never done and in place upgrade of Windows 10 or Windows 11 for the annual/semi annual updates, I can't speak for certainty, but from various comments and articles I've read, some of the privacy settings get reverted back to default after the update, so you have to reset them anyways. If I'm wrong, let me know.
In WIN 11, I just go to Settings -> Privacy & Security, go down the list one by one and turn just about everything off that I can and I disable all applications and services on start up, except for those absolutely necessary. Takes 90 seconds top per computer. I do nothing with the Start Menu or taskbar settings since I use OpenShell and ExplorerPatcher and import the configurations for each. Once OpenShell is installed, I then can remove the vast majority of metro apps that come preinstalled and can run in the background that you typically can't uninstall unless you run PS commands.
Then I load the latest Admistrative Templates for MS Office, make the changes I desire with those, which is pretty much blocking macros and the legacy Office file formats, make a few other changes in GP Editor, make a couple changes in Secpol and move on. Takes 2 -3 minutes per device. I used to do a lot of registry modications, but I don't do much anymore
I don't understand why you say it can be a serious pain if you have a lot of drives installed. Do you mean HDDs/SSDs, optical media drives, etc? Not sure what you consider a lot but, my laptop has 3 SSDs and a BD ROM drive, my desktop has 4 SSDs and two BD burners. Prior to the reformat, I disconnect all SSDs except for the boot drive so I don't format the wrong one by mistake and then plug them back in afterwards. Never had an issue and don't find it to be much of a pain. Just have to enter the BitLocker Recovery key and change the drive letters.
ExplorerPatcher doesn't fully work with 24H2. Most of the features still work, but some, like reverting to Win10 Taskbar are disabled. I did go through privacy settings after upgrading and they were still toggled off. I DID have some Startup programs that needed to be disabled again
The developers came up with their own Windows 10 style taskbar that works for 24H2 and it is virtually indistinguishable from the taskbar Microsoft removed the coding for that ExplorerPatcher enabled. The only thing that I cannot get working is the Windows 10 battery flyout (Windows 7 style does work though), which is not a big deal for me.
Reactions: Foxbat and HipKat
Ohh, that must have been added after I installed the app
If the permissions are restrictive (as they probably should be with such a moth-eaten OS security system), getting access to files after the installation can be a real PITA. Sometimes you have to run command line utilities multiple times wrest back access and control of files.
Reactions: Foxbat
2024-10 Cumulative Update Preview for .NET Framework 3.5 and 4.8.1 for Windows 11 Version 24H2 for x64 (KB5045934) and 2024-10 Cumulative Update Preview for Windows 11 Version 24H2 Build: 26100.2161 for x64 based - System (KB5044384) have been released. Moderate time needed for those wishing to perform a manual download/install/restart. New system features and quality improvements come with these updates.
Camera: dji Osmo Action 5 Pro
