New Hopper install and EHD
r2s26
7
Waldorf, MD
I just had the hopper installed today. Do I need to transfer the shows from the EHD to the hopper first? I thought I would just be able to see them and play them directly from the EHD.
Nothing. Don't even need to call it in.
The ViP211 has the $40 fee.
How do I go about seeing the shows on the EHD? When I go to the EHD icon, all it asks is if I want to transfer to the Hopper or vice versa.
You found the answer but in case anyone else has the problem:
Connect the EHD's USB cable to any on the 3 ports on the Hopper or a powered/unpowered hub from one of them.
Insert the drive's power brick in an outlet. Unpowered drives may work.
Accept that you added the drive after it indexes the contents.
Press DVR and notice there is a gray button between the red and green ones, labeled with a name you chose.
Move to it and select it and the drop-down menu will list your local name and External Device 1 and E D 2, if a second one.
(Suggestion: if you are far from the top, then just press red and right twice.)
Select one and go from there. You can view or delete shows as needed.
You can select Folders by Title/No Folders or select DVR Date/A-Z/Rating/Most Watched for the ordering.
As you found there is in Menu+2 down+3 right an External Hard Drive tile which allows transfers between EHDs and the IHD.
This seems so different that the other operation on the EHD.
-Ken
Interesting Joey Problem
Select recordings to go to ehd
