I recently went back to directv after being gone for over 3 years the main receiver they gave me for the living room is the genie Gen 3, is this a 4k receiver?
View attachment 130945 listed as; HR54-200
Oh ok. The new genie 2 Tower with the 4K client is newer than that. See if you can get that
Tried to get the installer to install the towered genie but he said that it was only for existing customer upgrades.
You got the correct information- The reason is Because With the HS17 - You can NOT have any (as in) NONE of the current receivers - the only thing allowed on your Account with a HS17 are Client's (MINI's).
By offering it to existing customers -they can remove a lot of older receivers out in the field. -
It's not up to the tech, it's a company decision. At some point new customers can probably get one.Why wouldn't a tech want to do a new install with the Hs17? Wouldn't it make sense to get all new customers on board with the latest and greatest?
Neither can the HS17, and it can do two 4k streams, the HR54 only one. That's the only advantages I see since you can't use an HR24 with an HS17.hs17 has too many issues, stick with the hr54
the hr54 can not do 4k unless it has a c61k with it
