Why is it so important to set the motorized dish to True South? For me, that is SatMex 5 (I am in San Diego, latitude 33, longitude 117 west, magnetic declination +12). This satellite, according to the List, has few channels that I can receive and only one strong transponder with no channels. So, what would happen if I used 97 West to align the dish and motor?
To add to what Tron said, when you are aligning on your true south sat, what you're doing is setting your declination. If you are at the top of the arc, after you set your motor's elevation, the peak signal when adjusting the dish elevation will give you the proper declination. If, however, you AREN'T aimed at your true south sat, it is possible to come up with the wrong declination, particularly if your mount isn't aimed south (the motor mount MUST be aimed south to track the arc properly). Ie a combination of incorrect declination and incorrect alignment of the motor mount can result in a peak signal if you aren't on your true south sat.[1] Why is it so important to set the motorized dish to True South?
Again adding to what Tron said, I think an explanation of what declination is, is necessary. In general, what you do when you align a mount is to set the rotation axis of your motor "almost" parallel to the earth's polar axis. The sats are located in the earth's equatorial plane, and since most of us are located north of the equator, if your dish is mounted on a pole ~ parallel to the earth's axis, and looking perpendicular to that axis, as it rotates, it will sweep out a plane that is thousands of miles ABOVE the equatorial plane where the sats are. For your dish to see the sats, you need to aim your dish LOWER, by 4 to 6 degrees, to look down to that equatorial plane. This is the declination. And this declination is a NEGATIVE angle of about 4 to 6 degrees. You say above that this declination " is really the elevation". This isn't quite true. You are adjusting the declination with the dish elevation, but the dish elevation is NOT your declination. Your dish elevation is a positive number, not negative. There is no way to set a negative declination using dish elevation. However, with these small motorized dishes, you attach your dish to a BENT motor axis. In your case, it is bent down by 30 degrees. This gives you a declination of -30 degrees, which is too much, so to get the proper 4 to 6 degree declination, you have to add 24 to 26 degrees of dish elevation.[2] The manufacturer instructions state I should set the "declination" (which is really the elevation) to around 25 degrees. What exactly is this supposed to achieve? Is it supposed to be close to my True South Satellite once mounted? I understand the reason for setting longitude, but how/why do they know what the dish elevation should be to acquire satellites?
3) The important thing is to be certain the mounting pole is ABSOLUTELY LEVEL when the motor is on it. This is very important, as it affects how accurately the motor tracks the arc.
Do I need to somehow "center" the bent motor pole, since I previously moved it all over the place? If yes, how do I make sure it is where it needs to be? Or do I just acquire the True South satellite and all is well?
Thank you !
I have read all your postings and thank you immensely for your sharing your time and knowledge. I will profess that I don't totally understand the reason for True South satellite being important, but I DO understand it is important and get the general idea. I learn more every day, and with a pretty solid math background, will one day delve into the details.
I will get the inclinometer tomorrow and give it a whirl over the weekend, then post back. I do have a few questions about some of the terms in the reply:
(1) What is the "reference position" I keep hearing and reading about? Is that the True South satellite?
(2) What is DiSEqc 1.2 motor control?
(3) What is "horizontal" and "vertical" frequency of a transponder (I've been meaning to ask that for a while, as I keep seeing it on the channel information)?
(4) AcWxRadar, what do you mean by "using the board across the face of the dish" in your instructions for using the inclinometer? Can you kindly post a drawing or picture, if words cannot describe it?
And lastly, thank you AcWxRadar for the warning about the SonicView Premier. I do have a SonicView Elite that I just got today for a second TV, so I will try driving the motor using that instead, once I set it up.
Thank you all again, and I will post back after playing with this over the weekend. One reason I always wanted to get into this was that given many years of college math classes, I felt it would be an interesting and practical application of knowledge that so far has not done produced much for me. I do indeed find that to be the case. I save all your responses and reread them when I can, so please know your time and efforts are most appreciated and helpful.
.... unless you reset the motor when it was not at '0' (or reference), the motor should still move to the correct position for the satellite you are setting up with USALS. I doubt you reset the motor, as that isn't something that can be done accidentally. ....
I have no idea how it happens, but this has happened to me a couple times. Actually, my motor came new with the reference zero off 2 or 3 degrees. After living with it for a year or so, I reset it to the proper zero. Used it this way for several months, then found that the zero had reset itself by about 12 degrees. Reset that, and used it for a few months, and then found that it had reset itself be a couple degrees again. I reset that, and it's been fine since. But somehow, perhaps some electrical glitch or corrupted diseqC signal, the darn thing seems to somehow get it's zero reference position changed. I'm thinking that perhaps it isn't a complete hard reset that's occurring, but rather an accidental "resync" command being sent to the motor, because I don't think that the stored diseqC-1.2 sat positions got erased. It's just that the zero gets changed, like you tell it to goto zero, and it goes to 12 deg instead.
T......
Your motor already has a stored list of satellite positions from the factory (just like the HOME or reference position). But, if you locate one of those satellites by driving the dish around via the DiSEqC 1.2 menu commands and you SAVE/STORE that position, it overwites the factory programmed location and stores your new location for that satellite. ....
...... Everybody else said the same thing I just did but in a much longer way. ....
I didn't take it as criticism. I was about to apologize for not knowing when to shut up before you posted. I just used to be a (very poor) teacher, and have this compulsion to make sure that every detail is discussed when usually the fewer words the better.BJ- I am close to Saco. I enjoy reading your posts in all threads and have learned from them. I was just trying to underline the point in other people's posts and didn't mean it as criticism.
The second thing relates to something Radar said, and is more of a question than an answer.
This pre-programmed satellite list is something that I have NEVER understood. It just makes no sense at all to me.
First of all, the pre-programmed list is generally a list of European sats, most of which we can't even see from North America, and the pre-programmed sat numbers are generally in the #1 thru #26 positions. But the thing that confuses me, is I don't see how they can possibly actually store sat locations in the motor, because those positions would be different for every different lat/lon of the motor users. I wish that I had experimented with my motor when it was new, just to see if it would actually try to GO to one of these positions, because I really don't see how it could possibly have anything meaningful stored there.
What I really think makes more sense, is that the pre-programmed list was really more a function of the older receivers than a function of the motors. Ie my first diseqC-1.2 receiver had these positions pre-programmed into the default satellite list that came with the receiver. Ie if I selected say PAS3, it would already be programmed as sat position # 24, but I'm guessing that it would still have to be manually located, and manually saved into the motor, because I really don't understand how it would be possible for them to actually store sat positions into the motor without knowing the lat/lon of the person who buys the motor. That being said, the motor manuals sure make it sound like there is actually position data in there, but it doesn't make sense to me.
Related to this though, this whole thing about pre-programmed sat positions, was really annoying to me, because my first diseqC-1.2 receiver wouldn't let me use the first 26 sat positions. Ie if I wanted to start my ARC at say G18, and save that as #1, it wouldn't let me, because the first sat position number for manual entry was #27! It turned out that I could use a channel editor for the receiver, and then get access to the position numbers 1-26, but it made it a complicated procedure for using the first 26 position numbers, and I had so many sats that I wanted to save, that there weren't enough positions between 27 and 60, so I needed to use the first 26.
Newer receivers don't do this, they let you use the first 26 positions, but often they do this at the expense of not having any access to the sat position numbers at all. Like with the Mercury II, you don't have any control over what position numbers you're using unless you use a binary editor, and go in and enter position numbers after the fact (assuming that they have been stored in the motor by some other receiver, which is what I had to do).
Anyway, I'm curious what other people think, relative to how these pre-programmed sat positions were actually supposed to work, for people in Europe who could actually see these sats? Were there actual positions stored in the motors, or was it just the relationship between sat and position number that was involved (ie this wouldn't really have ANYTHING stored in the motor).
I just can't figure out ANY possible way that pre-programmed sat positions could be implimented. I must be missing something.
B.J.
I really don't understand the notion of "Pre-Stored" satellite positions within the motor, either. Although it does exist. I pulled out my manual for my DG-280 motor and it lists the satellites that are Pre-Stored in it. They range from 15.0°W to 148.0°W and include C and Ku band sats, albeit outdated (i.e. 148.0°W is no longer there, and 123.0°W is listed as Galaxy 10R etc.) Then again, I bought this motor a few years ago so it is older.
Here is the crux and what makes me wonder... At the top of the page, it states:
*Pre-Stored satellites are based on Columbus, OH / Location: 40.0 N, 83.1 W
It almost seems as if the pre-stored positions are directed towards and only useful to someone at that location, but that surely cannot be so. Why would you bother storing a list of 60 satellites that is only applicable to one area? That doesn't make sense. There has to be more to it than just this.
Hmmm? Maybe we should ask Sadoun to help explain this?
Speed Dial: Sadoun
RADAR
