Windows 10/11 Download
it...is...simply...not...there.
and no modded uefi available that may insert it.
Intel(R) Core(TM) i7-6500U
I've upgraded two Dell Micro Form Factor PCs (7040/7050) with that CPU recently to Windows 11 with no issues. Just download the Windows 11 ISO file, and use Rufus to make a bootable USB drive to install from. Rufus gives you the option to modify the installation files on the USB drive to bypass all the compatibility checks, and it also gives you the option to make the install default to local accounts vs. Microsoft accounts.
Reactions: Foxbat and Tweek
Just watched a video on Youtube for Asus enable TPM. See if bios has advanced and trusted computing option. Enable trusted computing if you have it to turn on TPM. If laptop or PC is older than 2016 it may not have it from what i've seen from watching Youtube.
Stripped-out versions of Windows have been around for a while now.
If you have a machine that can only support 2GB of RAM, you should e-cycle it immediately. It probably won't function as a daily driver unless you run a modest Linux distro on it.
RAM is EVERYTHING in Windows.
That said, there's a pretty good chance that Microsoft will eventually close the loopholes used to make these versions (i.e. declaring the install as a server OS to get past the hardware qualifications)
Reactions: lordodogg
2025-01 Cumulative Update Preview for .NET Framework 3.5 and 4.8.1 for Windows 11 Version 24H2 for x64 (KB5050577) and 2025-01 Cumulative Update Preview for Windows 11 Version 24H2 Build: 26100.3037 for x64-based Systems (KB5050094) have been released. Moderate time needed for those wishing to perform a manual download/install/restart. Quality improvements only. No new operating system features.
Reactions: primestar31
There were a couple preview updates released today.
This is consistent with Microsoft's typical fourth Tuesday payload that replaces the previous schedule of third (C) and fourth (D) week updates. Microsoft calls these "optional non-security preview updates".
As is typically the case, this month's update includes patches for functional items that the previous Patch Tuesday update broke.
For Windows 10 users, the new and oft-reviled Outluck gets installed alongside the old ("classic") Outluck.
It successfully updated to version 24H2, Build: 26100.2894. However, it no longer can see my network devices through Network Neighborhood automatically.
Is this still an issue for you?
Last night I discovered Network Neighborhood is populating again for me.
I don't know, it's on a headless server. I'll RDP in and check.
Nope, still the same. SMBv1 stuff doesn't show in Network Neighborhood. SMBv2~ stuff does show. I can map devices after I made some changes, BUT, it doesn't show without mapping it.
Reactions: EarDemon
2025-02 .NET 8.0.13 Update for x64 Client (KB5052978) and 2025-02 Cumulative Update for Windows 11 Version 24H2 Build: 26100.3194 for x64-based Systems (KB5051987) have been released. Moderate time needed for those wishing to perform a manual download/install/restart. Quality improvements only. No new operating system features.
You're grossly underselling the importance of this month's attempts at fixing Windows.
There are 55 issues flailed at. Many are related to Windows features that most don't use. Some of these probably should have been removed from Windows long ago (like Internet Connection Sharing since dial-up is a distant memory) but that's not particularly comforting. Does anyone use Windows Telephony?
The announcement comes with four zero-days; two of them exploited.
2025-02 Cumulative Update Preview for Windows 11 Version 24H2 Build: 26100.3323 for x64-based Systems (KB505293) has been released. Moderate time needed for those wishing to perform a manual download/install/restart. Several new features and quality improvements come with this update. There will be a gradual rollout for this update and it's new features.
