Ill wait till the install and see what looks easier. All the coax feeds drop into my AC blower closet, which is real close to the ent center in the living room. The sat guys run the dish lines thru the attic and drop into this little room, then easily wire up as many rooms as needed. Seeing how close it is, I could buy a 20 foot pc of coax and run it from the closet, down the wall, and behind the ent center. Youd' never see it.
Here is an image of my living room setup:
If you notice on the right, on the other side of the FSU shrine lol, there is a small white door. That is where ALL the coax feeds for the house drop in, and where the sat guys drop there lines from the dish. If I understand you correctly, they would run two cables to that space, and into the "node". They would then take one cable out of the Hopper port and tie it into the coax that connects to the jack behind my tv stand. They would then take coax out of the Joey port, and connect it to the cable that feeds the jack in my bedroom.
Now, when I bring the Directv box and tv in now, I set them on the sub. It seems I could just buy a 20ft run of coax, and on Saturdays just connect to a joey portion of the node in the closet, run out and behind the tv stand to the sub, then bam, joey has signal. Is that correct?
Thanks.
Whenever we build, one of my requests will be that i have two jacks in the living room next to each other, with separate feeds to make this easier
