TV Fool and antennaweb are ok... but why not go directly to the source....
TV Query - TV Technical Information - Video Division - MB (FCC) USA
do the stations within a radius search of the database... 475 as max radius. This will give you all tv stations within 475 km of your location, all in a nice format that you can drop in to excel and sort to your hearts content by distance or by degrees.... much more detailed info and way more hits than either antenna web or tvfool give. Yes, tv fool and antenna web are probably more accurate for most signals in that they are highly conservative in what you will get, but with this thing you can get an idea of all channels, so if you have a rotor and good tropospheric conditions, you get a better idea of where to try to aim. Even better... you can get this list, export it, sort by degrees, and then compare it to tv fool to find the signals that are close enough and they'll be ordered in degree... would be very nice if normal tv rotors could do something similar to fta box type USALS, but that time hasn't come yet.
