One Dish (500 maybe? it is old) with a DP Quad LNB
522 in one room with 2 sat connections
512 in another with 1 sat connection (replaced a 508)
A few days ago the 522 can only pick up channels on 110, the 512 can only pick up channels on 119. Good signal strengths on both. (but shows signal loss on respective boxes for the sat that it can't "see")
Ran a check switch, got the message about "less satellites than previously found". Took a chance on the 512 and tried the switch trick where you pull the sat input from the receiver, let the test fail, save, then re-test. It didn't work. On the re-test, it only pulled in 119 and says NONE on switch now instead of the DP QUAD.
Any ideas?
BTW.. I very much like and appreciate the environment here, nice to see all of the real help.
Any ideas?
