Stargate Atlantis: Fans Choice ... dts Lossless Audio, like the SGU discs... I wish "Vegas" was included...
Syfy Version (5 commercials edited out)ID : 1
Complete name : L:\SGA McKay & Mrs Miller.ts
Format : MPEG-TS
File size : 3.24 GiB
Duration : 43mn 21s
Overall bit rate : 10.7 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 43mn 21s
Bit rate mode : Variable
Bit rate : 9 574 Kbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.154
Stream size : 2.90 GiB (89%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Duration : 43mn 21s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 119 MiB (4%)
Language : English
Recorded with Hauppauge, edited with VideoRedo... (used media info for the stats) my WDTV showed the Syfy version as stated... 41 minutes and some change...General
Complete name : L:\Syfy\SGA\SGA McKay & Mrs Miller.ts
Format : MPEG-TS
File size : 3.16 GiB
Duration : 43mn 22s
Overall bit rate : 10.4 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 43mn 22s
Bit rate : 9 315 Kbps
Maximum bit rate : 16.1 Mbps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.150
Stream size : 2.82 GiB (89%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 43mn 22s
Bit rate : 384 Kbps
Language : English
Yeah, wait till you see Enemy at the Gate...![]()
Vegas is on late night / early morning Thursday / Friday ...
PQ was really good (Directv version) I was really getting into till they (Syfy) put on Sanctuary screen spam taking up much of the lower L/H portion of the screen... even late night they put spam on the screen. turned it off and went to media playerThanks for the heads-up!![]()
PQ was really good (Directv version) I was really getting into till they (Syfy) put on Sanctuary screen spam taking up much of the lower L/H portion of the screen... even late night they put spam on the screen. turned it off and went to media player![]()
Watch it yet?
Blu-ray for '<i>The Complete Series</i>': Online Listings give Date, Cost, Specs, Art - 9:20 AM 4/14/2011 "Stargate: Atlantis - The Complete Series" is coming to Blu-ray Disc...despite word from the studio a couple of years ago that fans should never expect it. We've got the available info, including early box art, at the TVShowsOnDVD News!
URL: Stargate: Atlantis DVD news: Blu-ray for Stargate: Atlantis - The Complete Series | TVShowsOnDVD.com
