Software update from 110 satellite only?
Sorry for misleading, seems dish reduced number of software dramatically for 110 recently;
I recal a couple months ago it was around 60, now it show only 32 and (surprise :( ), your 5000 SOL:
DN tpn21@110W. Current FW list:
PID:0860h, ID:67UD, FW:p248, Model:DP301e.
PID:0861h, ID:60SD, FW:p309, Model:pVR501.
PID:0862h, ID:3YED, FW:p342, Model:DP301d.
PID:0864h, ID:3ELD, FW:p350, Model:3900.
PID:0867h, ID:41UD, FW:p214, Model:DP301e.
PID:0869h, ID:3CLD, FW:p239, Model:3900.
PID:086Ch, ID:J9TC, FW:BWE1, Model:DP301d.
PID:0873h, ID:16WD, FW:129P, Model:7100.
PID:0880h, ID:59RD, FW:854P, Model:2700.
PID:0881h, ID:5ARD, FW:854P, Model:2700.
PID:0882h, ID:6VBD, FW:839P, Model:3000.
PID:0884h, ID:4RCD, FW:846P, Model:4000.
PID:0886h, ID:58RD, FW:854P, Model:2700.
PID:088Eh, ID:49RD, FW:798P, Model:2700.
PID:0890h, ID:47ZD, FW:L314, Model:DP322.
PID:0891h, ID:4QXD, FW:L296, Model:DVR522/DVR625.
PID:0892h, ID:13CC, FW:L288, Model:DVR942.
PID:0894h, ID:14CC, FW:L288, Model:DVR942.
PID:0895h, ID:4PXD, FW:L296, Model:DVR522/DVR625.
PID:08A0h, ID:2FDC, FW:p317, Model:DP311.
PID:08A1h, ID:0HFC, FW:p277, Model:DP111.
PID:08A2h, ID:3BEC, FW:p380, Model:DP811.
PID:08A3h, ID:0HMD, FW:p298, Model:D351.
PID:08A4h, ID:3CEC, FW:p380, Model:DP811.
PID:08AEh, ID:38EC, FW:p380, Model:DP811.
PID:08AFh, ID:JITC, FW:p380, Model:DP811.
PID:08E0h, ID:02JC, FW:M101, Model:2W_MP.
PID:08EFh, ID:JXTC, FW:AFA1, Model:2W_MP.
PID:08F0h, ID:06PC, FW:1119, Model:DVR942/ViP622.
PID:08F1h, ID:HTTC, FW:1119, Model:DVR942/ViP622.
PID:08F2h, ID:03PC, FW:1130, Model:DVR942.
From 148W:
DN tpn19@148W. Current FW list:
PID:0853h, ID:1HBC, FW:L277, Model:DVR921.
PID:085Eh, ID:JYTC, FW:BNB1, Model:DVR921.
PID:0863h, ID:2LHD, FW:p322, Model:4900.
PID:0865h, ID:0NQD, FW:115P, Model:3750.
PID:0866h, ID:JMTC, FW:CJE1, Model:pVR501.
PID:0868h, ID:J8TC, FW:BKE1, Model:DP301e.
PID:086Ah, ID:XSTD, FW:01ZF, Model:1000.
PID:086Bh, ID:JQTC, FW:CLC1, Model:pVR501.
PID:086Dh, ID:HNTC, FW:BWD1, Model:DP301d.
PID:086Eh, ID:66UD, FW:p248, Model:DP301e.
PID:086Fh, ID:JATD, FW:01ZF, Model:4000.
PID:0872h, ID:19ND, FW:855P, Model:6000.
PID:0874h, ID:2IFD, FW:842P, Model:1000.
PID:0875h, ID:1HDD, FW:819P, Model:5000.
PID:0876h, ID:0XJD, FW:822P, Model:DSR100.
PID:087Ch, ID:12ND, FW:784P, Model:6000.
PID:087Dh, ID:2HFD, FW:842P, Model:1000.
PID:087Eh, ID:C3TC, FW:BGC1, Model:6000.
PID:0883h, ID:4TCD, FW:847P, Model:4000.
PID:0885h, ID:88T5, FW:0000, Model:ZZZZ.
PID:088Ch, ID:4QCD, FW:846P, Model:4000.
PID:088Dh, ID:6UBD, FW:839P, Model:3000.
PID:0893h, ID:46ZD, FW:L314, Model:DP322.
PID:0896h, ID:K4TC, FW:CMA1, Model:DP322.
PID:089Dh, ID:IWTC, FW:CUB1, Model:DVR522/DVR625.
PID:089Eh, ID:35ZD, FW:L246, Model:DP322.
PID:089Fh, ID:39XD, FW:L253, Model:DVR522.
PID:08ADh, ID:K7TC, FW:AUH1, Model:DP311.
PID:08B0h, ID:0IAC, FW:L268, Model:ViP211.
PID:08B1h, ID:0GKC, FW:L359, Model:ViP622.
PID:08B2h, ID:JNTC, FW:AEJ1, Model:DP422.
PID:08B3h, ID:K6TC, FW:APF1, Model:ViP622.
PID:08B4h, ID:JRTC, FW:L268, Model:ViP211.
PID:08B5h, ID:J5TC, FW:ANB1, Model:ViP211.
PID:08BDh, ID:JPTC, FW:APD1, Model:ViP622.
PID:08BEh, ID:8BTE, FW:DUMY, Model:ZZZZ.
PID:08BFh, ID:ESTC, FW:ACP1, Model:ViP622.
From 61.5W:
DN tpn29@61.5W. Current FW list:
Not sure about 118.75W and need to check 105,121 and 129; as you can see for real 119,148 and 61.5 have it.
Check signal for that particular home tpn on selected sat.
No that’s fine. No need to do the other satellites. Thanks for doing that
What TP did you use for 119? It doesn’t show on the original posting (on page 2)
I am assuming 11. I know my signals are good on 119. When I originally put that LNB up next to my StarChoice LNB I had 115+ on all TP’s (minus spotbeams). This was using a 301 (which since has been sold)
it worked :)
Went out and did some cable swapping. Hooked the 5000 up to a line for 119.
TP19 had a 90 signal (considering it goes to 100 max thats good) :)
check switch
made sure updates was set to on...even pulled the card for fun
turned the unit off and came up to find this thread. went back less than 10 minutes later and turned unti on...P819 for software :)
get 101, 103, 213, 262 right now. 265, the PPV and sports package chanenls are there but anything that isn't a PPV type channel is black screen (since the card is blue)
Thanks P Smith for helping out :)
Iceberg, good to hear your 5000 is up with the times. AFAIK, the 5000 and the DSR100 (5000 bundled with a JVC D-VHS deck) are the only Dish receivers with OTA that don't require a live satellite feed to receive OTA.
Sometimes, I miss my DSR100, it was a good receiver.
Activation Problems
MLB HD (9467) Blackout question
