self install, which birds?
Stern_howie
14
Toronto
Hello,
Going to do a self install.
Which birds do I need to hit for SD & HD, 110,119 and 61.5?
What size dish would I need? I'll need 3 LNB's one for each sat correct.
thank you o'wise ones.
Not illegal to point a dish in the sky afaik. But let's not get started down that road. Maybe someone else can answer my question. Thank you.
Not going to debate you, but have fun trying to break the encryption if you are doing this without a Dish sub.
I see...and what kind of switch would I use to 'combine' the 3 lnbs a standard Diseqc? I'm going down to 1 receiver either a 211k or DVR 612 most likely
you're only going to need 61.5 and 72.7 which you can easily get with one dish 500 with 2 single lnbs on a Y yolk. Just add a little extra space (about .75") between the lnb eyes.
If you do a search on the forum for "61.5 72.7" you'll get some good how-to info.
You need one dish with a DPP lnb and the other with a DP single. The DPP has an LNB-in port to connect them together.
Maybe" Bell Satellite" is more appropriate for this .
Last I checked the rules here are simple.
You live in Canada, NO USA satellite's for you from Directv, or Dish Network.
So again why is this topic aloud?
Please help me fix a year long issue (acquiring satellite signal)
VIP722k Delay End Time Setting
