We drove our RV from California and arrived in StPetersburg, Florida yesterday where we lost our HD programming. We have satellite TV service with DishNetwork, with a triple LNB dish designed to pick up signals from satellites 110, 119, and 129. Most of the HD channels, as you probably know, are transmitted from satellite 129. After setting up my dish with the aid of Dishpointer AR Pro for iPhone, I got good signal strength on 110 and 119 (55 and 70 respectively), but no signal for 129, even after many tiny adjustments to azimuth and elevation, despite the fact that Dishpointer for iPhone and for iPad both showed that satellite 129 was well clear of any obstructions.
I called Dish technical support, and after being guided through several (irrelevant) procedures, the technician eventually informed me that “satellite 129 is very low in the sky, and a different dish is needed”. I already own an “Eastern Arc” dish designed to pick up satellites 61.5, 72.7, and 77.0, so I intend to set that up. However, my first question for Satellite Guys is, do I point my dish so that (a) 72.7 is in the center of my iPhone screen, or (b) 61.5 and 77.0 are equidistant from left and right respectively of my screen.
Surprisingly, there is a big difference in skew between the two options: for (a) the skew is -17.2 whereas for (b) it is -22.6 degrees. Enough to completely miss one or two of the satellites!
My second question is, does anybody know why I can’t pick up satellite 129 on my western arc dish here in St Petersburg, despite the fact that Dishpointer AR Pro can clearly “see” it?
