I hate for this to be my first post, but I guess there is no other option. Had 2 hopper installed last week (one with Sling) and 4 Joeys. Within an hour the Joeys would go into the "Looking for a Hopper to connect to" message with the 1303 error code. Prior to going into this mode the Joeys and the Hoppers would show a full 4 bar green MOCA display and worked fine. If they reconnect by themselves (usually not) they would show as "connected" to the hopper with everything looking good on the diagnostic page, but would show "unliked" on the "whole home" page. At that point you could only watch what the hopper was already tuning. Anything recorded on the DVR would not show on the Joeys. Only a hard reset would correct the problem. The Joeys would then operate properly anywhere from 20 minutes to 2 hours and then disconnect again. Sometimes instead of disconnecting they would simply "lock-up" similar to what you see when you watch a youtube video that is buffering due to slow internet connection.
So, I call customer service for a service call. A very nice tech shows up and fixes a coax where the initial installer put a screw through one of joey coax lines where a splitter was intstalled. That does not fix the problem so he changes the Duo-node and the splitters. He then changes some terminations. That does not work either so he spends time resetting Joeys/hoppers, etc. He then flips the Joey's around in two of the rooms and that does not help. He is completely baffled after 2 1/2 hours and tells me that it is probably the hopper causing the problem, but will need another service call from someone with more technical knowledge. As I sign his ticket on the phone he has he tells me that he will initiate a new service ticket and Dish will be getting with me shortly.
Well, I wait until noon the next day and get no reply from Dish, so I initiate a chat session with tech support. They set up an appointment for 8-12 on Tuesday. I take off work on Tuesday and wait until 10:00 AM thinking I would get a text update. I did not get one, so I started a new chat session. The new rep informs me that I had no appointment (even though one was made), but will make one immediately for 12-5. I'm already home, so I take the rest of the day off. Nobody shows up, no phone call, email, text, nothing. At 5:40 PM I send an email to customer support asking them what I should do with the system as I no longer want it. I should have stayed with DTV I guess. I can understand technical problems, but I do not understand them not showing up for appointments.
