They haven't made an mpeg2 receiver since around 2007.
That would mean that the newest mpeg2 receiver out there is a minimum of 6 years old.
It took lots of subscriber churn for 6 year or older equipment to still be available in large quantities.
As far as the defective 522's. it's only logical that they would have the modulator disabled if it was broken. If it worked, logic would say they would have left the modulator active.
This is obviously NOT true. The 512 is a much more capable device with two tuners and PIP.2) The 512 is the exact same as the 510, it is just a newer version.
Not if they were trying to make a single room unit, which is what they were doing. Same thing with the 311k.
All they are doing is writing software to call a 522 a 512 and basically eliminating it from running in Dual Mode, and I believe allowing it to operate on a single tuner. Why disable the output, if its not broken?
So when is the change to 8PSK suppose to be finished?
That is exactly my point. If the modulated output is broken, there is no need to put a shroud over it. It's almost certainly "live" and they put a shroud over it to prevent customers from using it. There is probably no way you can turn it off in firmware. Unless somebody comes on here with a 512 whose shroud has been removed, we'll never know for sure.
Thats the million dollar question.
The longer Dish waits, the more customers who will churn out meaning the less equipment they have to replace.
For the converted 512s, the tv2 RF out is not active. I've tried.
Live, mirroring TV1?
Yep. Just like any other two-TV dual tuner.
