Preferred connectivity ranked from highest to lowest based on Dish documentation:
1) Hardwired ethernet to only one Hopper in your system for both OnDemand and DLNA - One ethernet connected Hopper will bridge all the devices in your system for home media and OnDemand. (Do not connect more than one)
2) Hopper Internet Connector (HIC) – a dedicated MoCA bridge that provides you an easy hardwired solution when you have ethernet access near a joey or via a client line connection. HIC is preferred when you don’t have ethernet access at your Hopper location.
3) Wifi Adapter – 1 adapter needed at a single Hopper location in your whole system
Extra Notes:
WARNING: Connecting more than one H/J device to your home network/internet after the s213 update could result In serious stability issues with your entire H/J system. Connect only 1 hopper or use a HIC.
Hardwiring in general is preferred over wireless as it's less prone to interference, difficulty in setup, and connectivity issues.
The HIC has been the most reliable method of hardwired connectivity since launch. Highly recommended among users on the forum. HIC is very flexible since it makes it easier to swap around Hopper and Joey locations. You’ll never have to worry about networking in the future. The HIC is also provided free during the initial H/J install.
Wifi adapters are also provided for free during the H/J install.
In some instances, bridging may be turned off on the hoppers. You can re-enable bridging with the info in the topic linked HERE.
Extra Notes:
