bowens said:No, I did not replace any wire. I also did not remove the amp, I just unplugged the power to it. I know the problem has to be these pine trees that aren't more than about 20 feet away from the antenna. I might end up moving it to the other end of the house to see if that helps.
A direct line from the antenna to the tuner is what we are asking you to do to help diagnose the problem.
Remove the preamp from the antenna and disconnect the powersupply. Of course just unplugging the preamp is going to make the picture worse
want the model number of your preamp stamped on the bottom of the preamp.
which channel from this list are you having problems with that you desire to receive?
red - uhf WGFL 53 CBS HIGH SPRINGS FL 92° 16.7 53
* red - uhf WGFL-DT 28.1 CBS HIGH SPRINGS FL 92° 16.7 28
red - uhf WOGX 51 FOX OCALA FL 124° 36.3 51
red - uhf WCJB 20 ABC GAINESVILLE FL 106° 27.7 20
* red - uhf WCJB-DT 20.1 ABC GAINESVILLE FL 106° 27.7 16
red - vhf WUFT 5 PBS GAINESVILLE FL 81° 28.1 5
* red - uhf WUFT-DT 36.1 PBS GAINESVILLE FL 81° 28.1 36
* blue - uhf WOGX-DT 51.1 FOX OCALA FL 124° 36.3 31
blue - uhf WGEC-LP 33 FMN CHIEFLAND FL 169° 10.7 33
blue - uhf WBXG-CA 31 BOX GAINESVILLE FL 90° 26.0 31
violet - uhf W69AY 69 REL ALACHUA, ETC. FL 89° 33.1 69
violet - uhf WYPN-CA 14 IND G
