Issue with wireless Genie clients
GoBigRed79
10
Omaha, NE
Good Morning,
About three weeks ago we had DirecTV installed. We got a Genie server with 3 wireless clients. We went with the wireless setup because we were spoiled by our previous cable provider who offered them. It was the only thing they offered we really liked. We like being able to setup a TV in the garage or in the backyard for parties, plus it reduces the number of receivers we need as we have a guest room that the TV is not regularly used in that we can easily move a receiver to when we have guests. Also my wife likes to re-arrange rooms so she likes how the TV's can go anywhere.
In the past week, and issue has developed and I am not sure if it is an issue I need serviced or just an annoyance with the wireless tech. Basically what happens is when I power on the client it comes on to the last channel being viewed like normal, but it won't change channels, the guide does not work, basically it is stuck on that channel. The video is playing like normal, normal sound, just can't do anything else. Simply doing a power cycle on the client fixes the issue, which leads me to think it could be some type of handshake issue when the client is powering on and connecting. The issue has happened on two different clients, so it is not confined to one. So far I have not done any hard resets or the server or clients as doing a power cycle of the client has worked to fix it, but since it started it has happened about once every other day. I have had no issues at the hardwired TV. Has anybody else experienced this?
One presumption is that the initial firmware update from Genie DVR to each wireless mini took place (initial tech installer should not have left the premises without making sure this happened).
Assuming that had already occurred, since you are reporting that you're getting a signal without issue (just can't do much else), consider completely powering off the Genie DVR as well as the minis. Then, boot up the Genie DVR, wait until it's fully up, then bring up each mini, one by one, and confirm that basic functionality is available per each mini (not all minis at the same time).
If there are still issues, you could try performing a reset on the mini client, but by this point, assuming having performed the above, you're now in a great position to take the situation to DirecTV. DirecTV would have made you go through the same troubleshooting technique anyway.
Hope this helps!
Reactions: GoBigRed79
Hope this helps!
Thanks! I will give this a try. It's just weird because otherwise everything works great.
Recording HBO Free Preview
Looking for best deal
