Here is my chat with the unhelpful rep. Anyone have any ideas? What is it an onsite tech will do, or is it possibly an issue with the bird? My LOS is clear and check switch says all is well. $49 for a tech call, or $29 with DHPP?!?!?!?!?!? Is that a new thing? I have never had to pay for a tech call.
Please wait while we find a representative to assist you. In order to ensure we are providing you with the highest level of customer satisfaction, this conversation will be recorded.
You have been connected to (24DrDcb) Kim H.
(24DrDcb) Kim H: Thank you for choosing Dish Network Chat Support. Please give me a moment while I review your technical Issue.
Matt Hay: Sure thing
(24DrDcb) Kim H: Can I get the phone number that is on the account with area code?
Matt Hay: *********
(24DrDcb) Kim H: I'm not aware of any problems that we are having with these stations.
Matt Hay: I tried both hard and soft reboots on the receiver and no luck. Was not sure if there was an outage. I have a 50 signal on Point Dish for 118
(24DrDcb) Kim H: This is just happening on you local HD channels?
Matt Hay: Just those 2 local HD stations
Matt Hay: others are a-okay
Matt Hay: KSDK and KTVI are the ones at issue
(24DrDcb) Kim H: Ok, lets go in to the menu and press 6-1-1.
Matt Hay: TP 18 I have 8 signal strength
Matt Hay: all other TPs are around 30-40s
(24DrDcb) Kim H: Lets go ahead and select check switch and then test.
Matt Hay: okay, it is testing
(24DrDcb) Kim H: ok, give this just a few moments.
Matt Hay: It is complete
(24DrDcb) Kim H: What is the results?
Matt Hay: All came back green
(24DrDcb) Kim H: 119 110 118 all ok?
Matt Hay: 110 119, 118, and 129 al green
(24DrDcb) Kim H: Ok, go ahead and cancel out of all the menus.
Matt Hay: ok
(24DrDcb) Kim H: What is it doing now?
Matt Hay: Was acquiring and is not dowloading guide
Matt Hay: now*
(24DrDcb) Kim H: Ok
Matt Hay: It is dine
Matt Hay: done*
Matt Hay: Still no dice on channels 002 and 005
(24DrDcb) Kim H: Ok, sounds like you may need a tech out.,
Matt Hay: okay
(24DrDcb) Kim H: It does look like if we got someone out it would be a charge for $49 or we can sign you up for the dish home protection plan for $5.99 a month and get someone out for $29.
Matt Hay: Let me give it a day or so and I will get back to you guys
(24DrDcb) Kim H: It was a pleasure assisting you, do you have any more questions for me?
Matt Hay: No, thanks for your help
Matt Hay: Have a good one.
(24DrDcb) Kim H: Thank you for being so cooperative throughout the chat session and also for providing me an opportunity to assist you today.
