Is HD TV really needed?
The converter box program expressly prohibits the use of the coupons for any device that has a video display or any recording capability. Also excluded are devices with HDMI, component, toslink and firewire outputs.
In other words its for a SD digital to analog converter with either RF or composite outputs only.
Jim 5506 is correct. I have even hard that these boxes are unlikely to have S video. The program really is just a way to not immediately obsolete all the analog TVs. It si not trying to stimulate digital sales.
Interesting. do they have NTSC tuners but not ATSC?
They have recently unloaded most of their NTSC only Series 2 boxes that were being pushed as CATV only, but now they have a NTSC+QAM Series 2 DT box which doesn't have ATSC capability either.
TiVo Series 2 DT disclaimer said:
Supports recording from cable and satellite sources only; does not support recording from over-the-air antenna or high definition.
TiVo would seem to be telling a bit of a white lie.
I gue my urprise is that you could market a set with an NTSC tuner without an ATSC one---regardless of the addition of QAM and the marking that it is for cable. Out of curiosity could an actual TV be sold this same way?
It is the rare cableco that uses NTSC. But it's probably not worth their time to go after them- short time problem, even if Tivo survives.
"Digital" cable means nothing- it's ATSC that matters.
I realize that the cable co would not use NTSC but unless I read the earlier post incorrectly these tivos have NTSC but not ATSC tuners. I thought that was verboten.
80% of cable is NTSC. Only digital cable is QAM and there are scads of small cable companies all across the country that are using digital cable as a premium. Even here in Lubbock our largest cable co is primarily NTSC with a premium digital tier in QAM. If I was a local cable sub instead of Dish, I'd already have one of the new HD TiVo's @ 299.00.
I'd like to see a link on that. Just because there is a lot of analog cable left, does not mean it's NTSC analog. Note that the frequencies are different, and spaced differently. Read this. Also, consider IRC, HRC etc.
If my 15 year old portable set can pick up basic CATV, you can pretty much bet it is NTSC analog. NTSC is not a set of frequencies.
QAM is digital - so they are compliant, because they are listed for cable.
The requirement, as I understand it, is that the device be able to tune ATSC channels if it can tune NTSC channels (they're in the same frequency range). QAM <> ATSC.
On Planet Earth, NTSC is what is used for analog.
All of the VHF band channels use the same frequencies and the same broadcast technology (NTSC). Changing or adding frequencies doesn't change the underlying encoding technology.
If you don't believe it, change a CATV connected TV from CABLE to AIR some time and see if you don't see quite a few channels.
On Planet Earth, NTSC is what is used for analog.All of the VHF band channels use the same frequencies and the same broadcast technology (NTSC). Changing or adding frequencies doesn't change the underlying encoding technology.
OK, if you want to get snide, in this little argument over the meaning of words, NTSC is NOT what is used for analog on earth. There's also PAL, SECAM, etc.
NTSC was defined for OTA use. Cable came much later. Yes, the frequency offsets are the same. The signal structure itself is basically carried over. But there are differences on cable, often beyond the simple reassignment of actual frequencies. Some degrading or changes in the signal is often done. For example, Media General once owned the cable system in Fairfax VA. They remodulated the signals of even the non-premium channels so that you could NOT plug the cable directly into your TV set and get a viewable picture. They wanted you to rent a box from them for every TV you owned. You could get an aftermarket box that would "correct" the signal for most, but not all channels. Cox Cable bought the franchise and this nonsense went away. But the cableco I had in NC did similar games, to a lesser extent. There are enough cablecos in the country doing similar alterations that you can buy aftermarket boxes to correct the "non standard" signals put out. BTW, MG system was so poor they used two cables, which they called "twin thorax." Poor bandwidth.
NTSC as defined does not allow for such variations. But then again, NTSC was designed for OTA. So any system that is based on NTSC, but allows for changes in frequency assignments, signal modulation variations, oddball encoding, etc, should not be called NTSC, IMO. You seem to feel otherwise. We are arguing over how we want to define certain words. It's not worth the time or effort. Especially since we won't be seeing much of it after- when is it that the requirement drops? 2012?
My Hitachi 57" RPCRT HDTV has a cable tuner. I use it to watch OTA stations because while the channel names are different and there are channels inserted between VHF and UHF and below channel7 and between channels 4 and 5, the modulation system is still NTSC, frequency is irrelevant, NTSC is the way the information is modulated into the 6MHz bandwidth allocated for each channel.
Unlike ATSC and QAM, there is no other system used in the United States for analog TV transmission of TV whether cable or OTA, well unless you consider IP, which must be converted to NTSC for all analog TV's to see it...
I'm not talking about scrambled channels. I'm talking about basic cable; the kind that doesn't require an STB. It is plain vanilla NTSC -- no ups, no extras.
I'm not sure what you're trying to argue, but it is clear to me that TiVo is trying to pull a fast one by offering a device that has an NTSC tuner but no ATSC tuner.
I agree that Tivo is pulling a fast one. But the channels I refer to are not scrambled. Just modified. They made of point of differentiating between these and the scrambled, premium channels.
HD OTA, Hard Disk and DVD Recorder with HD Tuner?
Samsung ATSC tuner missing channels
