Doing a self installation and it's not going as planned (zip 90064)
Here is what I have:
3 Satellites going into a multi-dish switch dpp44 (on the left side, room for 4 inputs).
A line going out from the bottom (labeled to power inverter) to a power inverter dp44 then into a dpp seperator which splits it into 2 lines which feed the 622 all is fine and working properly.
there are 3 other outputs on the bottom labeled to receiver satellite in
How do I get the 211 hooked up?
if I take the line that was hooked up to the 622, and run a check switch I only get the 110 satellite
if I run a line from 1 of the 3 outputs to the 211 and run a check switch I don't get any satellites
I haven't activated the receiver yet, don't I do that after all the satellites are recignized?
thanks
thanks
