I have found through many e-bay "adventures" it is better to pay a little bit more and buy one from a dealer. You will have support after the sale. And you are getting what you expect.
I have been doing business on eBay since 1999, and those are my thoughts exactly. And I must admit it is a lesson I learned the hard way.I have found through many e-bay "adventures" it is better to pay a little bit more and buy one from a dealer. You will have support after the sale. And you are getting what you expect.
Well, maybe. Mine from a WELL known dealer was bad. They kept on attempting different "things" for me to try to get it working. It never did. That took almost three weeks. They finally agreed for me to send it back. That was expensive. Now after being at their location for over two weeks, I still am having a problem with them answering my question, "what have you found out?" It has been a trying time with this "bad" unit. What I am expecting is they will claim it is OK and want me to pay big bucks again to get it shipped back. If that happens it is going to be one expensive S9 and a useless pile of junk.I have found through many e-bay "adventures" it is better to pay a little bit more and buy one from a dealer. You will have support after the sale. And you are getting what you expect.
Do you have an S9 or S10, and what firmware are you using?
I have an S10 and am using the "Aug 15th" firmware that really is for the S9, because it has the U.S. birds. I cannot find S10 only firmware anywhere.
Well I have been messing with this thing some more and I have to say that the DVR feature is pretty sad. You can rewind a live show but you can't rewind then press record. If you try that it just deletes the rewind buffer and begins to record at whatever point is LIVE. For instance, I am watching something. The time is 8:45pm. So I sit there and watch another ten minutes and I think to myself, "hey, this is pretty interesting, I want to rewind and record this." The time is now 8:55pm. I press the rewind button and rewind 10 minutes backwards in time to the 8:45 point then press record to record all the material that was transmitted to me starting at the 8:45pm and everything else forward of that time. So, it is now 8:55pm, I rewind to 8:45pm. So far, so good. Then I press record. BOOM... It totally dumps the buffered video, it's gone forever. It then begins record only everything that was received ONLY from the actual real time that I pressed the record button at 8:55pm.
As far as I know, all FTA DVRs work this way. The second you hit record, you wipe out the timeshift recording. The work-around is NOT to hit the record button. Just turn off the receiver after the program you want recorded has ended. Disconnect the hard drive from the Openbox and connect it to a PC. The timeshift file will be there, and can be copied over to the PC.
Do not turn the Openbox back on with that drive connected until you have either copied the timeshift recording to the PC or renamed it, as it will be overwritten.
The Visionsats work the same way, and I assume other FTA DVRs do as well.
How well does it work?
How about one of those programmable learning remotes? I have one from radio shack thats probably 20yrs old, controls up to 8 devices, and even has timers built in. Surely they still have them, or the Harmony remote has a model that will. Teach it the 'record' button on your fta remote, set a timer, point it at the fta box and let it turn your recorder on-the remote has its own clock. And it's accurate! There;s usually more than one way to skin a cat. I used mine to have my IRD move my big dish , tune a channel and then turn on the vcr , record a program then turn it off again, all while I slept. And if it was an analog channel, I could have it move the dish back to a Videocipher channel when it was done recording, so I wouldn't lose my authorization for programming.
The other night I used it to record the new IRT Deadliest Roads. It recorded it into two files, both are .mpg. One is 1gb and the other is like 487mb.I'm not liking that it breaks the file up like that. How the heck do you put it back into one file? Or even more important, how do you prevent it from doing that in the first place?
I saw another recording I made a few days ago, a test recording of something on RT. I had just let it record for an hour or two. The file is a .ts file and it was like 2.7gb in size.. I would prefer the files stay in one piece but I would like to have them in the .mpg type, I think the .mpg files are supposed to be smaller?? I don't know.ay to fix the clock. If you do, PLEASE clue me in!
Oh, and another thing, I powered the thing down and discovered the timeshift file. I was able to play it back on my pc and save it to my pc and I can cut and save the pieces I want out of it. So the previous suggestion about doing that was correct and extremely helpful. I'm actually going to do that again in a little bit, something is buffering now that I didn't hit record in time for. So I can power down, plug it into the pc and save it.![]()
the original Sathawk (which I owned...the predecessor to the S9) had the same clock issue. So its been like that for over 18 monthsthe "problems" with the clock have been posted over and over and over.
