Is pressing the Hopper reset button the same as cycling power to it?Have any other Dish receivers had a reset button?
Is there any "practical" difference between the two?No, it's not.
Pressing the reset button only resets the software. Power cycling will reset both the software & the Hardware.
For example, when would you Reset and when would you pull the plug?
Sounds good -- I've been using it whenever I switch sat arcs.You would first try a RBR,then if your problem is not solved you would plug the plug.
