I got a TT3G50F which works up to 3ghz. I found out about from SatGuys in forum post. It is made by Alpha Delta Communications
Alpha Delta Communications . The following from a link on the left side of the page to a pdf
http://www.alphadeltacom.com/pdf/TT3G50F-2.pdf which describes the one with the needed F connector. I used one on the H3 at the receiver as well as one at the Joey. BTW, I also put one right before my cable modem. If the surge protector part blows, you can replace it and not have to "cut" it out and put in a new one. Just screw in another protector.
I emailed AD and asked if it was ok to do that as opposed to mounting at the ground block (or hybrid hub in my case) because I read in the pdf that it should work. He said it is not best, but it can help.
The reason behind my choice is that my hybrid hub is outside in a box and the coax travels on the outside wall to the H3 in one direction and to the Joey in another. If a nearby strike were to hit, the surge might travel toward the equipment as well as the hub which is grounded. I want to protect the H3 and joey in case that happens and having the TT3G50F right before the receivers can do that.
I understand that in a direct strike, all bets are off. However, a nearby strike can cause a "wash" of electricity that might be picked up on a coax. These surge protectors should be better than nothing and even better than running through a UPS; / anti surge type device. Aside from possibly not having the frequency range needed to pass a signal, I have read that it is not the best idea to protect low voltage equipment from surges on the consumer type UPS devices which makes sense to me.
I have had no issues with these at all. In fact, I do not see lower levels when I check the sats/transponders in diagnostics, have had no picture loss or pixelation, and MOCA signal is still always good and the screen that shows throughput has not changed.. I am on EA (2 sats) so according to the Dish info I have, my signals probably are not going much over 2150mhz anyway.
I bought mine off ebay (search for Alpha Delta TT3G50F (make sure you get the F). They are less expensive than buying from AD. The replacement plugs are only $15 according to Alpha Delta.
