yes, depending though where you are located.go a little down and to the west,from the 110/119
setup,and do a check switch.you will lose the 110 and pick up the 129.
still works the same way with that dish also.you should be ok in wisconsin,if the tree situation isn't too bad.it will only pickup 119 and 129. not all of them together
