Yep, I followed that part of the discussion. The Dynamic Link Library is something you don't mess with.
You can thank Brett for that idea, He made Quaker Oates famous on here by that idea.
Sounds good to me, Keep those probe cables as short as possible. You don't want them like 3'long. Just jumpers. Anything under a foot would be great.
The terminator cap is fairly cheap so it's worth it to get it.
Sure, The RFconnection out of MD,
Link found Here
They can make custom cables for you and their prices are quite good for the connectors. They carry cable too and more.
Well, lets examine your question..
Again lets use the formula for calculating free space wavelength.
We'll calculate to the nearest thousandth of an inch .000" as you measure with a caliper.
234 divide 1694.1 Mhz = .138* X 12 = 1.657"
234 divide 1686.6 Mhz = .138* X 12 = 1.664"
So the difference is .007" of an inch between HRIT and GRB.
I can't build a wavguide to that tolerance, It would have to be machined. The can it's self will vary that much in the sun on a hot day.
So in the world of waveguides 1690 Mhz is well in the usable frequency range of all this we're doing.
Now you try to use a 2.4Ghz waveguide for this, it won't work as the 1.6Ghz is to large for the smaller waveguide to propagate in. It's below the cutoff frequency.
The opposite happens when you take 1.2 Ghz waveguide and try to use it a 1.6 Ghz. The 1.2 is bigger than the frequency of interest so 1.6 propagates in this guide but it don't do it well. It will cause several unwanted waveguide modes to be present and when talking circular polarization this is bad as these unwanted modes can cause interactions that mess up the original waveform.
You want a guide that allows one mode to be present, It don't mean that other frequencies above can't propagate in it. But those frequencies are not (preferred) for that guide. In simple terms a correct waveguide helps act as it's own high pass filter as most frequencies below the cutoff are not allowed in.
And the frequencies above it are attenuated to a point, that's why I prefer to use a longer guide as (mentioned before) it don't allow unwanted modes to propagate. It's length helps eliminate the unwanted mode. I was told that by Paul W1GHZ and have followed it to a "T".
Waveguides are not super narrow bandwidth devices (or high Q). Any guide (can) that works on WEFAX, EMWIN, HRIT, GVAR will work for this. It's just a polarization issue.
