Also, as you probably already know, the wavelength in the wave guide is longer than in free space.
Brett, if I think what your telling me is the wavelength in coax is longer then free space hold on a moment..
My ARRL handbook talks about making coax transformers and when the formula is given it's like..
468 OR 234 divide by Freq. X vel. factor.
So in the case of RG6 this would = 1.32" for a quarter wavelength.
Coax is not considered a waveguide in those terms.
I remember this clearly as I cussed a 2M beam balun when I missed calculating the vel. factor. Could not get that thing to match for nothing.
For any newbes here I will explain.
To find a wavelength in free space the formula is
468 or 234 divide by freq in MHz
468 calculates a half wave in feet
243 calculates a quarter wave in feet
So...
Example 234 divide 1686.6 = .138 close enough
times 12 = 1.66" Ahh, there's are wavelength in inches.
When you take the (times 12) this makes it into inches.
Lets try another..
One of my favorite FM radio stations is on 92.2 MHz
So we take 468 divide by 92.2 = 5.075 feet.
Since this is already above a foot we can leave it for the calculation, but we can do inches too.
times 12 = 60.9" That's the half wave for 92.2 MHz frequency.
When making transformers using coax the velocity factor must be calculated into the formula.
1686.6 MHz = 1.66" (from above) times 80% = 1.32"
That's a quarter wave in RG6 coax. Double the number 1.32 and you get a half wave = 2.64"
This is why I prefer to use the block combiner in my setup. Errors here and you can have all kinds of issues.
By dull I meant that there is no visible earth surface and dark, grey images.
Also, I haven't gotten a full disc image because the Windows version of GRBDump crashes when it tries to save them.
My goal is full disc color images in daylight. I know it will require combining channels.
Yep, you're wanting the visible images and those are big in size. I think a fulldisk is some ware near 450M in size. In a bitmap that's huge.
Any chance that it can save those images in a jpeg, png or gif format?
Default colors on the imagery is grayscale. It depends on how many grayscale colors are available as well to the definition of the detail.
Colors are usually added by the software displaying the imagery, For example on my GVAR system.
There is a histogram that I can open and change the values that represent the temps (on IR) so I can change what grays show and their intensity. It also allows me to add color to the images.
I don't know what GRBDump has, but if you're to get the RGB visible imagery it would have to add the colors during the making of the image.
It takes all 3 visible channels to make that imagery, as explained above 450M per image.
Unless the GRBDump does this on it's own, that's how I'm aware the color imagery is made.
Channels 1,2,3
his is a bit off topic, but there is a new XRIT decoder for Windows
Glad you let us know about that. Thanks.
Thanks for the magazine info as well.
