Not all the all the LNBs with those lot numbers are bad, but almost all the bad ones I see have those lot numbers. I like the super dish LNBs they are on average the are pretty reliable, at one point there were over a million in use, but I only have to service the bad ones. Even the bad ones work most of the time, they usually only malfunction when the temperature gets above 80 degrees. The bottom line is that the LNB will probably work now but if it starts to act up when it gets warm you should know why.
