D dish65 New Member Original poster Jan 24, 2012 3 0 minnesota Jan 24, 2012 #1 I install a 1000+ system but i can`t find 129 signal I have 110,119,and 118. What i did wrong,please help me Thanks
UTMTech SatelliteGuys Pro Oct 23, 2011 541 0 Jan 24, 2012 #2 dish65 said: I install a 1000+ system but i can`t find 129 signal I have 110,119,and 118. What i did wrong,please help me Thanks Click to expand... Did you remember to put up a dpsingle/dpdual for the side bracket to catch 129? If not.... Then there you go. Otherwise check to make sure you're not using a 1k4 arm(has a wire exit on bottom)& that the reflector isn't bent. Sent from my fingers.
TimberWolf SatelliteGuys Pro Jun 7, 2010 612 8 PA Jan 24, 2012 #3 if you have 118 you are pointed in the right direction, but the skew may be off what do your signal levels look like? are you sure you have line of sight to 129? post a pic of the dish and the view of the sky from behind the dish if possible
D dish65 New Member Original poster Jan 24, 2012 3 0 minnesota Jan 24, 2012 #4 Thanks guys for the tips I did rigth all the steps but I will review again and I will post the pic
D dish65 New Member Original poster Jan 24, 2012 3 0 minnesota Jan 28, 2012 #5 THANKS ALL FOR THE TIPS WAS THE SKEW
