I've been missing a few game feeds on Ku so I decided to motorize an old Primestar 1.2m dish. I plan on modding a prime focus mount for the purpose. So I need to know the offset angle of this dish.
I wish I had satellites H~H here. I'm at 114.0°W so I have sats for only 25° to the west and then I see the big void over the Pacific and finally catch 177W near the West horizon.I am pretty sure you will be able to fit your dish on polar-mount you have and it will go almost H-H.
I also considered that. The ring is essentially useless, just added weight. But it is a solid structure and easily adapted as is. I am going to cut the mounting ears for the C-Band dish off the ring and then check the fit to the dish. I think I can position it so that the dish will nest in the ring nicely when bolted down giving it added support. I have an idea for some rubber bumpers on the back of the dish where it contacts the ring. It should actually look pretty good. It's a small 23" ring. There is already a declination adjustment mechanism built into the bottom axis arm so that all I really need to do is replace the upper arm with a longer piece to add the offset angle. There is still a question off actuator mounting but I'm sure I can work that out.Seems like I had considered not even using the mounting "ring", and just starting with the piece that mounts to the ground pipe and the big square tube and going from there possibly?
Been so long since I set it up that I don't remember exactly what I did.But I think I modded the declination adjustment for the extra offset.Works from 72 to around 103 or so(roof gets in the way). Originally put it up just to get the DMX channels for the 4DTV when they were ku on the original X4 (99w),I just used the elevation adjuster to tune it in.waylew, I can't really tell from looking at your picture but have you allowed for the offset of your dish (increased the declination by 20-some degrees over what a prime-focus dish would need)?
I believe I have the mount finished. I have assembled the dish on the mount and all looks good so far. I need to fix up an actuator yet. I want to increase the counts per degree for this Ku feed hunter
View attachment 128594 View attachment 128595
I replaced the sensor in a VonWeis actuator with one of my making and doubled the counts. The original sensor was 40 counts per inch. On a 24" actuator that gives us 960 counts for a full stroke. I took it to 80 counts per inch , a 1920 count per full stroke.I used a larger magnet wheel with still only 8 magnets but all magnets polarized the same way. With the correct spacing of the magnets the reed switch closes twice with the passing of each magnet thereby doubling the count.
I need to find a pole to mount this on still. The actual installation may be delayed until spring. We already have had snow, the earliest snowfall in 34 years. But I will be doing some testing with the test stand and maybe watching a game tomorrow on it![]()
Spring is always a long way off in MontanaSpring is a LONG way away! Ground can't be frozen yet. Worst case you could always build a fire on top of the spot you want the dish, heat it up to thaw it, then dig the hole.
