I would say that FIOS iss definately better then Dish on HD quality.How does FIOS compare to E*?
Dish downresses all 1080i from 1920 x 1080 to 1440x1080. Fios sends it out in its native full resolution.
Thats ok, this is an example of what the report post button is about.
So use and Shhhhhhh!
QUOTE]
Nice use of quote button, get over it already.
Scobuck, thanks for the update from your guy. Can't wait.
Scott, its good to hear they could be bringing the PQ on these new channels.
My OTA locals and D* MPEG-4 locals are indistinguishable. I have nothing to compare YES-HD MPEG-4 to, so I can simply say it's amazing.
Unless you have ever been involved (on the inside) of a Customer Service Center, I understand the experience/perception people have about the knowledge/accuracy of CSR statements.
However, it's a monumental undertaking to ensure accuracy when you have a large number of agents possessing different skills and work motivations. Even the simplest things can become complex as it applies to cohesiveness and accuracy across the group. Especially when things are moving fast (to them - slow to us).
Since you want to go the inmature and childess route. You can kiss my simley face ASS!
NBC HD stinks everywhere. Their HD PQ is the worst.Surprisingly, I agree with you... I have only been able to notice occasional, very minor differences between my OTA locals (Indianapolis) and the MPEG4 channels on D*. I even plugged the OTA directly into my TV's digital tuner to make sure it wasn't the HR20 screwing with the picture...
A little bit of a disappointment, honestly, because I thought the problems with my NBC station were because of the satellite compression and found out that it's just the station's/network's signal that stinks.
No offense, but why don't you just ignore that forum? Why do you feel the need to belittle them or even pay attention?? Both sites have their contacts and their insight and have a place on the internet and within the DBS community (hence the reason I visit both: I'm a news junkie). Why nitpick about each other?? Where does that get either of you??
All depends on your affiliate, you can't claim that their HD stinks everywhere.
I am a software designer / developer so I guess I would be an expert.
If a large system works in testing and crashes when it goes live, the cause would most likely be one of the following:
1. Race condition (multiple threads / processes trying to access the same thing at the same time or process a depends on process b which depends on process c which depends on process a)
2. Networking problem (system a can't talk to system b, usually a domain or security / firewall issue)
3. Bad design which can't handle the required volume
4. Live hardware doesn't match the test hardware
5. Garbage data in the live system which didn't cause a problem in the previous software but is needed by the new version (should have been caught in testing -- always a good idea to test with a backup copy of the real data)
Number 1 could be the hardest to find. Number 3 would take the longest to fix.
As another software engineer, I agree with your assessment.
IMHO, number 4 or number 5 are the most likely because they are the hardest to simulate under test.
Numbers 1 and 3 are easy to simulate and/or model so shame be unto them if they botched those. 2 is a common one but is typically fixable with a quick slap to the forehead and the uttering of the word, "d'oh!", followed by a little bit of typing and mouse-clicking.
I'd also suggest 6, which is sort of a variant of 1 and/or 5:
6. Tasks running on the live system that were not running on the test system or were simulated too simplistically on the test system, which mangle data on the fly or usurp resources from the new software in ways that were not predicted or adequately simulated in the testing.
1. Fios
2. E
3. D
We will see if the coming weeks changes this.
They should get Vmware and create a test/dev virtualization don't you think?
