I needed a much more robust OS for editing HD (Blue Ray) video projects. The level of video called for more than 3Gb of RAM to be able to edit HD video in real time. So, that meant Vista 64 on a system with a dual Quad Core, 8Gb of fast RAM and triple SATA hard drives in RAID for speed. Now I can edit two streams of 1080p x 1920 video in realtime playback with effects easily and the rendering is faster than real time.
The only issues I had with VISTA 64 has been the security headaches where when I tried to install the 64 bit edit software along with a 32 bit version. There was a mistake I made in the first install registration and it caused me to screw up the ownerships. There was no easy way to fix it so I spent two days reassigning ownership and admin privleges on 132 files in a number of folders before the problem was fixed. So, that one issue, I can't blame on VISTA.
My two printers work fine with 32 bit driver sets. One is an 11 x 17 MFC Brother inkjet and the second one is a MFC Color Laser by Brother. I also installed Adobe CS3 Production premium pack and have no problems with those. The Ultra II vector keying software crashes when I try to render with video source from a single SATA hard drive but with a RAID dual stripe data drive it feeds the frames of video fast enough to not tie up the renderring engine.
My second Vista is a recently purchased Dell XPS laptop I bought for my wife. It is Vista 64 with 4 Gb Ram as well. The only issue she reports repeatedly is that it loses wifi connection often and needs to be rebooted to re-establish the connection. While I'm here, she called me and said this time the wifi would not connect after several reboots. I told her to plugin an ethernet cable to the ethernet jack on the wall in the KItchen and it connected instantly. I'll need to check that out when I get home as to why the wifi is no longer working.
So that's it. What bothers me is after what, 2 years with VIsta now, people are jumping on the windows 7 in the belief that this beta release will be less buggy than the current Vista?
I don't see that as even possible.
So is it windows 7 a version?
Windows 1, 2 and 3
Windows for workgroups
Windows Mellinium
Windows 2000 or Windows NT
Windows XP
so that tells me that Windows 7 is like version 8.0
Then we also had tghe 64 bit versions of Windows XP and Vista
I'll just believe Windows 7 is just a name and has nothing to do with a version.
