Solar Transit Calculator
For anyone who is interested, there is a nice solar transit calculator available (on-line) here:
Sun Outage Calculator
Twice a year, once in the fall and once in the spring, the sun aligns nearly perfectly with the satellites in the Clarke Belt. This generally causes prime focus dish owners to experience sun fade as the noise from the sun can overpower the satellite signal when it is directly in line with the satellite.
However, for anyone desiring to actually "SEE" where every satellite is in the sky, you can use this calculator to locate them by viewing the sun's position during a specific time window on a certain number of days during the spring and fall.
I usually enter the orbital degree of the satellite (rather than selecting the sat name). Then enter my coordinates (lat/long), Ku or C band and spring or fall and the dish size and year. Then I select my time zone and hit CALCULATE.
This should result in at least four dates and a time window on each date when the sun is aligned with that one specific satellite. Then go out and look at the sun's position during that time on one of those dates to see where the satellite is in the sky.
You will be amazed at how high the satellites actually are! This is also a very excellent tool if you are questioning whether any trees, buildings, a bluff or ridge or other obstruction is going to interfere with your reception. Not to mention, being able to directly witness exactly how high the sat is above the horizon.
I used this calculator to determine where the best location in my yard would be to install my motorized dish. I have many trees and buildings scattered all around, so I wanted to be certain that I located the dish closest to the house (to avoid too long of a cable run) and get a clear LOS shot to at least the majority of the satellites. I ended up with (if I remember correctly) 285+ feet of cable run. I used RG-11 cable for most of this and have no problems.
This calculator is assuredly mentioned somewhere else on this site, but I thought I would revisit it here as it has a direct application to the discussion and the time of the fall solar transit is approaching (beginning of October).
If you have the opportunity to be at home (or wherever you are setting a dish up) on the dates indicated, I urge you to check it out. It is really sweet!
RADAR
