What signals can you "see" at 61.5?
W.
Not sure I follow the whole cross-talk theory anyway. The Label changes from Transponder to Spotbeam, and the status changes to "Locked - Echostar 61.5 West." Seems pretty straight forward to me, but I am no expert.
Ted
W.
Ted
Sounds like a spot to me!
Post a picture if you can.
Just to be sure, if you can, do P Smith a favor and hang a piece of foil on the face of the 110/119 LNB and check your signals on 61.5. That way you'll know for sure the spotbeam is coming from 61.5. ;)
Placed a piece of foil over the lnb on the 110/119 satellites. Made sure I had no signals..............Went back to 61.5, tp 3, it locked on echostar 61.5, transponder changed to spotbeam , 92 signal strength. I have NEVER had a signal on tp 3, 61.5 until last week. My 2 dishes are 100 ft apart and if there are any switches they are inside the dish for the 110/119 satellites. On the uplinks last week, the Raleigh channels were moved to 61.5, transponder 3, spotbeam 5, n/a of course, but that is the future for them it appears. That is all the evidence I can supply.
I have noticed that the NBA and NHL channels in sd are MPEG4. Can anyone comment on these?? How is the pq??
10 Mar 08 - 11:50 AM CST
O'Fallon, IL 62269
61.5 - Dish 500
VIP722 - L4.49
NL = Not Locked
01 - NL Name Not Acquired
02 - 59
03 - 53 Name Not Acquired
04 - NL Name Not Acquired
05 - 55
06 - 71 Name Not Acquired
07 - 62 Name Not Acquired
08 - 71
09 - 62
10 - 67
11 - 60
12 - 84
13 - 48
14 - 78
15 - 56 Name Not Acquired
16 - 70
17 - 57
18 - 66
19 - 62
20 - 53
21 - 57
22 - 50
23 - 71
24 - 62
25 - 70
26 - NL Name Not Acquired
27 - 73
28 - NL Name Not Acquired
29 - 68
30 - 42
31 - 72
32 - 64
Thanks for the update. Some would like a 110/119 removal from the switch but the foil works just fine if placed on the face of the LNB and you verify that 110/119 are no longer working. Makes for a real easy removal and you can't break anything that way.
If you're showing spotbeam and locked on 61.5 then I'd definitely say you are on 61.5's spots as 110 spot would show as spotbeam but show as wrong satellite.
You don't understand the crosstalk problem, but you could easy follow that advise to connect your receiver to 61.5W only.
So far you're alone.
The switch is also on the roof, so that would be as difficult. I just don't see how cross-talk could cause the specific circumstances I am observing. I certainly would not expect a solid 91 signal from cross-talk. I would expect at least some variability in strength, and probably not a high strength reading. That said, my experience with cross-talk is limited to telephony, so my expectations may be incorrect.
Ted
Ted
I'm curious too, I'll wait on the photo from the signal screen.
area: 79109
Dish 500
VIP 622: L4.49
1.NL
2.46
3.50
4.NL
5.52
6.61
7.57
8.60
9.59
10.42
11.57
12.73
13.43
14.58
15.55
16.57
17.54
18.39
19.60
20.43
21.54
22.27
23.68
24.57
25.52
26.NL
27.64
28.23
29.47
30.23
31.61
32.52
Anyway, we need real spectrogram from that location where one or more person found 61.5W tp3 signal using direct connection to single dish pointed to the sats (E3/E12).
Not that desperate since the claim already posted. Perhaps if you see changes in signal level or description.
Can we circle the area on US map where is the tp3 "SB" registered ?
Anyone get better than low 30's signal on 61.5
I lost two HD channels in Puerto Rico
