What antenna do you recommend for my location
I did a troubleshoot on my coax cable, pre-amp and power inserter. I did find out that my power inserter on the TO TV exit was dropping my complete voltage to ZERO and therefore making it unsuable, I did check cable with a volt meter and it was good and pre-amp by visual inspection and it was good as well. I did order a replacement for my PCT-MPI-1G and now let's wait and see.
If other users has the same symptoms please refer to this youtube video in how to properly check your power supply, cable and power inserter connections. This is for a winegard pre-amp but all companies has the same principles:
Out to TV should be zero voltage you don't want to send voltage to the tuner of the TV set.
Good to know since based in video says to ANT and I thought it was TO TV, but if it's to the antenna then it passes the same voltage as received from ac adapter
Sent from my Nexus 7 using Tapatalk
KWTV Oklahoma News 9 Tower Coming Down
Crazy Antenna
