ViP922 and Local Channels on wrong sat... DIRT help?
kc8kfg
4
Cincinnati
I just purchased a 922 and activated this evening. All seems to be working well, guides are slowly populating and I receive all channels I expect to.
However... I receive Lexington, KY local channels, which are broadcast CONUS on the 77 bird and spotbeam on 61.5 (which covers the SE part of the market, but covers marginally where I live, not to mention trees blocking my line of sight on 61). My other receivers have no problem with local channels and default to the 77 loc, but my 922 only tries the 61 loc and gives me a poor signal message.
Is there any way to fix the 922 to only look at 77 for the locals?
Covering the 61 LNB and running check switch is out of the question (only solution I can think of) as the dish is mounted on two story roof.
Thanks!
Manually removing 61.5 would really be the only way, and you said that it was not a likely solution. There is no setting you can set within the receiver.
ESPN 1080p HD?
