Hi, I'm new to this forum and am hoping someone might be able to help me. I am attempting to install a VIP222K in my RV. I have tried with 2 separate satellites, one labeled DP Plus and one labeled DP. No matter what I hook it to, even if its not hooked to anything, as soon as I plug in the receiver it jumps to a screen stating Downloading Software from Satellite (step 3 of 7), Status: installing switch, there is no choice to go to a menu and pressing buttons does no good. I have a triplexer (which came with the receiver) attached to the receiver and also tried (separately) a DP Plus Separator with another switch which was left over from the previous installation of the satellite. After a while I get a screen telling me to check the connections to the cable lines.
When I press continue, I come to the Point Dish screen, which states Not Locked-Name not Acquired. It lists my Zip code, system type 500, Tuner input 01, Transponder 11, Satellite 119. If I click Done is says: "The signal you are receiving is not from the satellite you have selected. Reposition the dish, check the dish connection, or select the correct satellite".
I have clicked Check Switch, then it runs through 38 steps before crashing.
Can anyone tell me if I have a bad box, or if I have connected something wrong? Maybe I am using the wrong satellite? Any help would be appreciated.
Thank you
Thank you
