Using an antenna to receive local channels
bebop, I have a Sensor antenna with a Winegard Wingman attached to the antenna. This is (was) suppose to increase the reception. The one channel I am getting is a whole lot clearer. Now as to the connection that was working before. The installer for the HD DishNetwork did a change. Prior to HD, there was a Channel Master 4012IFD Diplexer that brought the satellite cable and antenna cable into the house. It was replaced with a grounding block. Now the satellite cable hooks into the receiver via a grounding block (splitter) and two cables connect into the two satellite inputs on the receiver. The antenna cable connects into the over the air antenna slot on the receiver.
I don't believe I have the proficiency to make my own antenna and do the hook-up. But, I might learn. I hope I have been clear about the set up. Thank you. dickie
