Just downloaded and installed H385. All good so far.
Sent from my SM-X210 using Tapatalk
Not to worry, I'm pretty sure H386 will fix the problems you find.Just downloaded and installed H385. All good so far.
Also, to add is the black screen upon H+ and J4 startup. Is Dish going to ever fix this issue?Just forced updated about 5 hours ago on the Hopper H3 on H383 to H385 with Hopper Plus on P13106 to P13112.
It appears that the current version(s) of DISH equipment on AndroidTV software are as follows:
Joey4 P53112
Wireless Joey4 P63112
Hopper Plus P13112
Josh.M and brittanygarden
Have the same issue as mentioned with H383 and earlier after updating.
The bar chart shows the DVR % is visible which for me is 100% even though there is 120GB of free space left on the internal HDD.
The issue of skipping to the beginning and end appears to be fixed from brief testing.
So still the three major issues:
Issue #1
H385 still has the issue where 119GB-120GB free is considered 100% full on the HDD so the last 119GB-120GB can't be used at all. The fix is either make it available with the correct % remaining or treat the HDD as 120GB less in capacity so the % meter for what's used is correct.
Issue #2
H381, H382, H383, and H385 has the issue where the Remote Control Mode Reminder Notification Mode Reminder Notification is always on where it will display that the remote needs to be in SAT mode when on TV and AUX even when Settings -> Notifications -> Remote Control Mode Reminder is set to Off. This was originally discovered by Pepper.
Issue #3
H383 and H385 and possibly earlier version(s) I may not be aware of has this issue where randomly, as we all know there is the 1 hour buffer on the current channel but let's assume the current time is a new program which was on for 10 minutes, it will not allow rewinding past the start of the current program as the buffer would be gone for anything before that part so one can only rewind back the the beginning of the current program and not the previous program. I believe what RTCDude mentioned in Hopper 1 Software H183, Hopper 2 Software H283, Hopper 3 Software H383, Hopper Duo Software H483 and Hopper Plus Software P13106 released & available might be related.
Josh.M and brittanygardenAlso, to add is the black screen upon H+ and J4 startup. Is Dish going to ever fix this issue?
