You may be right but...
According to the Dish site the Boston HD Locals are channel numbers 6318-6321. And these channels numbers are the ones that the EKB list shows are loaded twice on 61.5. They are available on the conus TP 21 and unavailable on the spot beam "5s16".
Talon Dancer
Companion for your snapshotAhh not so fast...
I took a look at the HD Temp Channels today on 61.5 and they are no longer all the same bitrate (indicating a static slate)
But today there is actual programming on all of those Temp Channels.
Take a look for yourself.![]()
From what I've read, the duplicate channel numbers are exactly what has fouled up digiblur's automated system due to a bug in TSReader.Looking at the EKB list, what's with all the re-use of channel numbers? Can they DO that? I see eight channels 5160 for example. And does that have something to do with why the automated reports quit working?
I haven't looked that close but I would guess that any duplicate channel numbers would have to be only on mutually exclusive spotbeams so that any receiver would only ever see one of them?
Yes. That is exactly the problem. TSReader, the tool Digi uses for the reports can only see unique channel numbers. John H uses a different tool so his reports are accurate when it comes to the duplicates.Looking at the EKB list, what's with all the re-use of channel numbers? Can they DO that? I see eight channels 5160 for example. And does that have something to do with why the automated reports quit working?
Correct. That is what I have seen as well with all these duplicates. I'm guessing that Dish is really fighting to keep the 1000-4999 range clear so that three digit channel numbers we use most often only require three button pushes without a long pause.I haven't looked that close but I would guess that any duplicate channel numbers would have to be only on mutually exclusive spotbeams so that any receiver would only ever see one of them?
I don't know the answer, as I don't have a 61.5 dish, but I would tend to believe SatelliteGuys info over a DISH CSR/Website, at least immediately after the change.I was just at the Dish network site, and looked into the availability of the HD locals for Jackson, Ms, and though the uplink did not show the Fox affiliate(WDBD 40) it is listed as HD available on the dish site....is this anothe Dish screw up?
Does anyone have an idea when the FOX station will be available? I wonder what the complication is for why it was left off the list.CHNG 5150 WAPT MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 16
TO 5150 WAPT{JACKSON, MS} MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w AVAIL HIDE HD MAP 16
CHNG 5151 WJTV MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
TO 5151 WJTV{JACKSON, MS} MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w AVAIL HIDE HD MAP 12
CHNG 5152 WLBT MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3
TO 5152 WLBT{JACKSON, MS} MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w AVAIL HIDE HD MAP 3
[/code]
Can anyone confirm that Greenville/Spartanburg SC HD Locals went live. I wouldn't mind moving home again.
Unless we're supposed to do something special to see them, they aren't showing up yet. I've got 250 package with HD and locals, but I'm not seeing anything "new" in regards to locals in HD.
Do you have a dish pointed at 61.5 west?
In order to receive those HD Locals you will need a dish pointed at 61.5 west. Dishnetwork can help you with that if you really want to get them.Actually, I don't think I do. I see 119, 110, 129. Am I supposed to? I am definitely a newbie on this stuff so thanks for any help.![]()
Im very amazed people take issue with paying $59 for a $40 dish and a truck rollout/install to receive hd locals Dish also has to pay for.
I still think youre asking too much.
