I'm having trouble with signal level on the 77 slot satellite on a 1000.4 and hoped somebody might have some idea as to what might be wrong....
Everything seems as it should be except for unusually low levels at 77.
Typical levels are 56-58 on 72.7, and 52-54 on 61.5, but only 25 on 77.
I've checked for vertical on the pole with a two foot level on all sides; I've verified line of site for all three EA satellites (wide open, with more than 10 degrees over the tree line at the worst point). I've checked the dish several times for any mechanical assembly problems. I also verified peak levels one satellite at a time, making sure I could clearly run through the peak on each regardless of the effect on the other signal levels, and the 77 location clearly will not exceed a signal level of 25 when running through the peak.
I've installed quite a few dishes, but this problem has me stumped.
I will add that this was not a brand new 1000.4 out of the box; the LNB was new, and the arm/components matched but the reflector was a bit beat up. I know any irregulaties in the reflector geometry will affect performance, but I'm guessing that's not the problem here.
I'd welcome any speculation on what might be going on.....
