Here is a chart of our US VHF-Low Channels:first want to see if I can pick up / receive a radio signal.
This scan, using an RTL-SDR V3 dongle and GitHub RTLSDR Scanner software, shows the channel 3 Pilot Carrier:
I hope they don't charge for ota 3.0There is one slight possibility is by E-skip or F2 Ionosphere skips conditions instead of troposphere ducting conditions.
We use VHF-low for various Full power and low power stations using ATSC 1.0 "8VSB modulation" and 3.0 "COFDM or OFDM modulation"
Via, E-skip and F2 skip over Atlantic Ocean to Europe is possible but not tropo ducting.
You may have to use VHF-low band TV antenna " 54 to 88 MHz range "
It will take time and patience to TV DXing but reward will be great.
Be aware we use 60 Hz with higher video framerates in 30i, 30p, 60p, and future 120p for ATSC 3.0.
Video resolution are, 480i, 480p, 720p, 1080i, for ATSC 1.0 and 480p, 730p 1080p and 2160p for ATSC 3.0.
Note: 2160p and 120 FPs are not quite put to use yet but will come soon in the future for our new ATSC 3.0 system.
I hope I don't get too technical for you, but we do have rich video flavors.
Like airline traffic, I believe the transmission from the United States will be coming into Europe over the Arctic region (shortest distance and all). Get a globe, a push-pin, and some string to measure the direction to the larger cities like Boston, New York, or Philadelphia (where the AntennaMan is located, I believe.) This will not be west-southwest, but more west-northwest.Well it's depends on your location, assuming you are in Europe and aim for USA is point your direct focus antenna towards west to southwest from Europe.
