I'm trying to pipe the 625 TV2 out into my other room TVs, which are on basic cable. So I modulated the signal to channel 78, and merged it with the cable signal by use of a simple 2 way splitter. The setup works, but the picture is bad on both sat (ch 78) and the other cable channels. If I disconnect cable from splitter picture is good. If I disconnect TV2 out from splitter cable picture is good. Why are the two causing noise? Do I need something other than el cheapo splitter? Radioshack sold me a single diplexer, but that didn't work. I tried using a high performance splitter (5 mHz - 2 GHz), but that made no noticable difference. Do I need a filter, I looked locally, but no one carries them? If your hardware recommendations aren't available at Fry's or Radioshack, please provide a link to where I can order it.
Thanks in advance.
Chad
Thanks in advance.
Chad
