Tonight & The Rest of the Echostar X Moving Schedule
All the Greenville DMA channels are now on 119 and are gone, I think, from 129. My signals on WGGS and WNTV are now much stronger. Not sure why I upgraded to a Dish 1000 in Janurary now. Would not have if Dish had told me this was coming when I called.
jc17981 said:
WGGS and WNTV are already mirrored on 129. You get a free dish upgrade if you call Dish Network.
Since it was free, just enjoy the ability to use anything in the future that they toss onto 129.
like others, this might have something to do with X and living on a fringe area: Burlington VT locals disappeared from my dish today in the AM. Were they scheduled to be moved as well?
Also, is there a map of the NEW spotbeams and where they're shooting?
110W Readings from Zip 21921, SD105, 522 DVR. DPP44, May 5, 2006, 6:30AM
TP 1 99
TP 2 111
TP 3 85
TP 4 53 SPOT
TP 5 99
TP 6 112
TP 7 97
TP 8 111
TP 9 99
TP 10 99
TP 11 99
TP 12 101 SPOT
TP 13 94
TP 14 109
TP 15 93
TP 16 113
TP 17 97
TP 18 98 SPOT
TP 19 98
TP 20 94 SPOT
TP 21 102
TP 22 110
TP 23 54 SPOT *Balt., MD Locals*:mad:
TP 24 102
TP 25 71 SPOT
TP 26 87 SPOT
TP 27 0
TP 29 0
TP 31 66 SPOT
What is the proper way to check the signal levels of your locals??
For instance, for Philly, it states it's on TP 12, Spotbeam 4.
SO, from the signal level menu, do I check TP 12 on 110? Or do I put in 4?
Burlington is on TP23
Here is the spotbeam coverage for TP23 VT spotbema (its in light blue). Blatimore is also on a different spotbeam (same TP)
Here is TP23...the restc an be found at www.ekb.dbstalk.com
nothing yet?
Still no moves yet here in Tulsa, are they supposed to be delayed or shouldnt it happ last night?
Tulsa, OK05-May-06TBD8920 11051 -> 248420KTULABCTulsa, OK05-May-06TBD8921 11051 -> 248420KOTVCBSTulsa, OK05-May-06TBD8922 11051 -> 248420KJRHNBCTulsa, OK05-May-06TBD8923 11051 -> 248420KOKIFOXTulsa, OK05-May-06TBD8924 11053 -> 248420KWBTWBTulsa, OK05-May-06TBD8925 11053 -> 248420KTFOUPNTulsa, OK05-May-06TBD8926 11053 -> 248420KOEDPBSTulsa, OK05-May-06TBD8927 110302 -> 248420KGEBINDTulsa, OK05-May-06TBD8928 110302 -> 248420KWHBINDTulsa, OK05-May-06TBD8929 110302 -> 248420KTPXPAXTulsa, OK05-May-06TBD8930 110302 -> 248420KRSCIND
DFW HD Locals
Any reports from DFW area? I still haven't seen any changes but we're scheduled for May 5th, right? E* tech support has no information.
FWIW - got the signal back for Burlington in southern VT.
Must be tweaking the beams as some have mentioned.
Regarding the other reciever my mom has (in Harrisburg, PA)
the way I read the maps, she should be able to pick up Bostons locals (she's a New Englander through and through :) ). #1 - is this correct, and #2 - what are the chances she "moves" there and they end up tightning that beam as well?
Sorry, I'm still not clear on this. How far up the Connecticut River valley (border of Vt / NH) will the Boston LiLs reach?
Im not really sure if this is the right area to ask this but, When I try to watch a local channel it doesnt work and the only works I go to XKJRH, XKOKI, XKTUL, etc.. Those had been there for a few weeks, but now the normal numbers for them dont work anymore starting today.
They moved my locals about a week ago and the signal is better. Here is each transponder.
TP 1 - 110
2 - 106
3 - 86
4 - 62
5 - 99
6 - 110
7 - 98
8 - 107
9 - 98
10 - 94
11 - 98
12 - 91
13 - 92
14 - 106
15 - 93
16 - 109
17 - 96
18 - 55
19 - 100
20 - NONE WON'T LOCK
22 - 111
23 - 85
24 - 107
25 - 63
26 - 75
27 - 45
29 - 79
31 - NONE WON'T LOCK
Later Boneman I live in Central Missouri I took these readings at 10:15 PM This the 110
I do have a dish 500. It even says I have one on one of thoses on one the dish channels, They were working last night on the channel numbers and now once again it is not working on the channel numbers. I looked and its getting a signal of 85 when it doesnt work on the numbers to. The transponders are around 80-100 like your post above, cept a few wont lock. The guys next door is working fine, His transponder 4 is at 88, and mine is at 84, and yet it still wont work even when its locked.
