Thank you Textin for your concerns, let me see if I can explain this so that the current method makes sense:
The difference in frequencies are due to many varying factors. Here's a list of a few possibilities.
Satellite receiver frequency detection.
LNB Oscillator inaccuracies.
LNB drift due to temperature. (At Iceberg's location there is a thing called snow, where I am located we have never heard of snow
Published frequencies are only theoretical or planned values, the actual frequencies can vary due to many factors.
(If you scan in the daytime vs. night time you sometimes see a difference.)
I am going to use Dish Network's 119W satellite as an example:
(I am using this satellite as an example only because I can get the theoretical frequencies very easily)
(All the below frequencies are using the same LNB and dish.)
Dish Network's NIT: 12238.580 MHz
Broadlogic: 12239.400 MHz
Coolsat:12239.000 MHz
Pansat: 12239.000 MHz
Dish Network's NIT: 12267.740 MHz
Broadlogic: 12268.500 MHz
Coolsat:12266.000 MHz
Pansat: 12267.000 MHz
As you can see from above not all receivers connected to the same dish and LNB will not agree on one frequency.
So when I do update scans if a transponder is already in the database and the current frequency and the last scanned frequency are different the two are averaged.
In the end having the frequency off by a little bit does not matter because the receiver has
PLL (phase lock loop) circuitry inside that will lock on to the correct center frequency.
I hope all of this make sense, if it does not let me know and I might be able to clear up any confusions.
EDIT - Iceberg - You gave me Hispasat updates after Textin's March 25 2008 post?
