So much for that then,I'll stick with my SWM-16 multi-switch.The swm13 multiswitch still needs 4 lines to feed it.
That writeup is for the SWM13 LNB, not the multiswitch.....The Solid Signal writeup shows only one connector so where do the other three connect? I think its one wire as an SL3-S.
http://forums.solidsignal.com/showthread.php/6837-Solid-Signal-s-HANDS-ON-Review-DIRECTV-SWM-13-LNB
The SWM-13 LNB is completely different from the SWM-13 multi-switch AND IF I CAN FIND AN ARTICLE ABOUT THE SWM-13 ONLINE,I'LL SHOW YOU THE DIFFERENCE(I'm about to throw my very slow Mac computer across the room).The Solid Signal writeup shows only one connector so where do the other three connect? I think its one wire as an SL3-S.
Ding, Ding, Ding !!!1 wire,2 wires........GOING OUT,I could beat myself in the head right now,NOW I GET IT.
Of course,both the SWM-13 & SWM-16 multi-switches need 4 wires coming in from an LNB,but the SWM-13 only has 1 wire going OUT to 1 splitter,while the SWM-16 has 2 wires going out to connect to 2 splitters. I don't know why I thought that the SWM-13 multi-switch only needed 1 or 2 wires running from the LNB to it.
Got a question for the real installers (unlike myself that do this as a hobby).
Doesn't SWM stand for Single Wire MS.
If that the case, Why do they call the other new device (SWM Multiswitch ) what they do, it clearly needs more than 1 line to feed it ....
Yes, but still confusing....The swm multiswitch is actually called a DSWM13, the lnb is a swm13.
I imagine once it shows up on Solid Signal,it'll be "flying off the shelves."...because it is not available yet and we don't know when that will be. Check with solid signal, they will be among the first to get them....
