I bought a Audiovox PNP1 on Clearance and the radio works well. The problem that I have is that the metal piece that connects the antenna to the PNP1 unit has separated from the cable. It looks like what happens when you remove the metal piece on the end of your tv cable. It looks like when the antenna was made that the metal sheath, that recieves the cable from the antenna, was glued to the metal piece that is surrounded by plastic at the beginning of the rubber/plastic coated section of the antenna.
My question is can this be repaired somehow. Both the antenna wire and the metal sheath are fine, I just need to fasten them together. If I reinsert the wire into the sheath and place it into the radio and strongly push the sheath and the antenna wire together, I get a strong signal. Any help would be great!!!
