I had a little ummm mishap pulling my wire thru the wall at work the other day. Does any one know for sure what end is on the antenna cables? My best guess so far is a RG58 BNC? Not sure if female or male. Any imput would be appreaciated.
sirius uses a cable connector called " smb .i think xm uses the same type of connector.i don't know where you can get the tool to put on these connectors. but they are called "smb connectors"
I have several antenna's that is not the issue, what I am doing is pulling the antenna cable thru a wall and it needs to be as small as possible, I guess I will need to put a larger hole then I wanted.
