Satellite Configuration
FranKy400
42
Currently, I have a 500 pointed to 110 and 119 along with a side dish at 61.5. My SD locals are on 110, but the HD has justed started on 77.
And I also want to add international programming that is located on the 118.
I have 2 dual mpeg 4 receivers, but would also like to add another.
Which configuration should work best? Will the 1000.2 and a side dish work, or do I need the 1000.4?
If it makes any difference, I am located in the Louisville, KY area.
Will the local SD channels remain uplinked for the foreseeable future or will they eventually be taken down?
Thanks in advance for all your advice.
As long as you have purple G3 cards for your receivers, I would suggest moving to the Eastern Arc with a Dish 1000.4, and a Dish 500+ running only 118.75 into the 1000.4's input.
upgrading 625 to VIP 622
