I have a craig CLC 504e tv and can't find a code to work on my 54.0 remote. Can't get it to learn either, any suggestions on a code?
Hi there! I hate to hear that the codes are not responding to your model of TV. An additional code you may use is "0180". - Christina W.I have a craig CLC 504e tv and can't find a code to work on my 54.0 remote. Can't get it to learn either, any suggestions on a code?
Just out of curiosity, when you press the volume button, which light on the top of the remote lights up, TV or Aux? Also, I'll post something on our tech portal and see if anyone can find that codeThanks Bobby, and HipKat, no luck.this is the remote from _ _'ll. Won't learn from the Craig remote either. Guess this is a two remote system, last cheap TV for me.
OK, just making sure, I've seen some out of the box that had the Aux Devices set to control by default. Hopefully someone on the portal will come up with a code for you. In the meantime, LG and Visio codes often work on other TV's, if you want to kill some time and try going through themTv light comes on
Did you try contacting the company?Thanks Bobby, no luck. I hate to give up on stuff but this seems impossible. Tv only couple years old, not sure why no code.
