Novice needs help in adding/connecting a Zenith VR 1862 VCR to existing setup of, one AKAI LCD Digital HD TV; one Phillips BDP 5010 DVD Player; and a Dish Network Dual Sat 625 DVR.. Purpose is to record and play back programs recorded on the DVR and further saved for playback to and from the VCR. The following connectors are in use or are available.
DVD player connected via component. (Green, blue, red) cable, (YPbPr) and associated R/L audio pair to like connectors on TV. Playback only No problem.
DVR TV 1 S-Video out, w/ assoc R/L audio to like connectors In, on TV, for Live TV play and/or record with recorder play back. No problem.
DVR TV 2 Coax cable out connected with splitters to other TV;s in other rooms. Play, record and playback, No poblems
Other DVR TV-2 connectors available-- Second set of RCA component Video and assoc R/L Audio out connectors,
VCR-- one set composite Video RCA In and out connectors available and one set single side RCA audio in and out available
TV-- One set AV-source, RCA composite video and assoc R/ L audo connectors available.
Have connected VCR-In connectors, to the DVR-TV-2, 2nd set of RCA- Out connectors, and the VCR Out connectors to the TV AV-source, input connectors . When I playback from a ..DVR recorded program to record onto VCR and then play from VCR to TV, I get only confetti type display similar to old TV loss of sync problem. Have tried both dual and single mode operation of DVR
Would greatly appreciate any detailed, step-by-step information for accomplishing the desired operation. Thank you
